New Craftsman T3200 Poor Man's Power Steering
DarkKnyte
In case anyone is thinking about doing this to their T3200, there is no room between the spindle and the bushings for a thrust bearing. It's already a really tight fit. The bronze bushings are press fit in the front axle really tightly, but if they could be removed, one might be able to grind down the flanges on the top and bottom to create the required room. Alternatively, you could take the spindle to a machine shop and have them grind out some room for it. Stock though, it does not fit.
Also, make sure you grease the spindles and axle really well. The steering had a small amount of grease, but the axle was nearly dry from the factory.
