new coil no spark
barnyard5
Tried 3 coils, .010 gap, good ground still no spark Tecumseh 5,5 over head valve
Remove the ground wire and check for spark. If you get spark the ground wire is shorting out the carb. Remember that the ground wire is only there to shut the engine off.
