I just bought a new carb for my YardMachine (linked below). The thing hunts and surges and won't run with the choke off. Well, it runs even worse with the choke off and wants to die. There's no adjustment other than the idle mixture. I've tried adjusting it every which way. I replace the carb in 2017 and recall the other one doing that too for at least a few months before leveling out. Any suggestions on this? Reason I replace was because the fuel shutoff solenoid started leaking. I've got half a mind to just replace that with the new one off the new carb and put the old carb back on.
