- May 6, 2010
- 12,035
Part of the issue maybe the bent throttle linkage in your second picture next to the red arrow. That linkage rod should be straight. So I am sure that linkage is binding on the intake manifold. If that rod was straight the throttle would probably be at idle. LInkage needs straightened or replaced and governor static adjustment needs reset.
