I've got a new Briggs & Stratton 7.5 that has a carburator problem. It tries to start but dies, checked the plug and its wet with fuel. I removed the carb and checked the float/needle and it's working correctly.
I finally got it started and it ran fine but I'm sure it will be a probelm the next time i try to use it. It runs great once you get it started.
I found a new carb for 34.00, should I try that?
