New Blades
jvancaster
I recently purchased some new Gator G6 blades for my Scag mower. My question is, there seems to be a protective coating like a varnish or something on them. Does that have to come off before I install and if so what should I use to take it off? Thanks.
You don't need to remove the coating, just install the blades and when you start mowing the coating will disappear.
Put them on. The grass will remove anything that needs to come off.
