- Sep 7, 2024
- 3,393
Hello C.,Thanks to everyone for their helpful input. I installed the D adapter and it seems to have stopped the chatter when idling. In reviewing the IPL it does not show a D adapter but a couple of coved washers that it does show, were not on the old clutch. I think someone replaced the original with the Warner that I removed which has D and the extra washer that an OEM takes were discarded. It’s the only way I can see how this happened. I used D and a single lock washer
Thanks again
Spit
I see the double D style adapter used on most riders with electric PTO clutches and the stacked pulley design use just the washers and bolt..
The IPL may have had an amendment or a technical bulletin after the original publication. I also find that IPL's are often recycled and cross over to many different applications.
