dougmacm
Did a bagging comparison test this weekend with the 40V 21" Greenworks vs. my 10525 Rear Bagger Lawn-Boy.
Reason I did this quick test was after two weeks of bagging, it seemed that the Greenworks 21" Rear Bagger held more grass than the L-B so with my wife running the GW and I running the L-B I figured the easiest way to compare bag capacities was to dump a couple of each into a Ryobi AC04313 Pop-Up Lawn & Leaf bag and measure the settled depth of grass. The inside diameter of this thing is about 21.5".
10525 with full 100-6362 bag of grass settled in at about 8" of depth at 21.5" dia. ... with simple math this calculates out to:
2639.17 cu-in = 1.53 cu-ft or 1.24 bushels which is less than 1/2 of L-B's published 2.5 bushels.
And YES, I was right the GW bag was 12" of grass depth at 21.5" dia. (50% more) or:
3958.8 cu-in = 2.29 cu-ft or 1.86 bushels.
This was really thick & green grass, so maybe the L-B 2.5 Bushel spec is for really dry grass !!
Don't think I've ever seen a "published capacity" for the Greenworks bag … anyone else know or seen it listed somewhere ??
Doug
Doug
