rwag77
- Jul 17, 2024
- 3
I picked up this motor on a 7,000w Dayton generator at an estate sale. It was still in the box so never been used. It was manufactured in 1999 I believe or close to that.
I did a quick look at the carburetor and all the seals look fine. I have a rebuild kit if I can even get that far. I put a little gas in the tank. I put oil in the motor. I hooked up a lawn and garden battery that holds voltage until you try to crank with it, then drops about half charge if you try to crank with it. I pulled the plug to see if I had any spark, but I didn't. I know the battery has a dead cell but I should still be able to pull the crank on the engine to at least get a spark. Everything looks fine, I mean it has never been started so of course it looks fine.
What am I missing? I usually can get small engines to crank without a problem. This one is giving me issues.
