Neighbors Troy Bilt Pony cranks slow then kicks back, think its the ACR?
Fires on starting fluid for half a sec then dies.
What does this tell you? Engine needs air, fuel, spark (at the correct time) and compression to run. She is thirsty........
Stuck on ACR I see. Ignored the fueling deficiency above.
Take some 2 stroke mix. Spray directly into the carb inlet. See how long she will run WHILE spraying 2 stroke mix. Throw the Ether in the trash.
