I just installed a new Kohler Command pro Ch680-3081. in a John Deere F620. The Oil filled , gassed, new battery, I primed the carburetor , it will crank but will not run. I suspected the engine wire harness and after viewing a loose wire from the back of the Kohler engine female connectors, I removed and reconnected the engine harness the engine started and ran. Now after I installed the muffler braces and supports, the engine will crank but will not start. In case that it may be a wire connected incorrectly or wires may not be making proper connections to the correct connector . Due to the difficulty in accessing existing Kohler wiring harness connector I would like to extend the connection harness connectors.to allow better access. I would like to remove the kohler plug and extend the wires , solder and shirk wrap them , attach wiring harness connectors in a way that they are easier to access. Wondering if anyone had any similar problems, or could it be some other problem I have over looked. Does anyone know the wire color codes for this engine? I cannot find that color code for the Kohler cH680-3081.
