T J Blazek
- Dec 19, 2012
- 3
- 37
Just purchased a RZT 50" zero turn. Want to find a rear bumper to pull a utility traier. Part # shown is NLA. Any suggestions?
Called the dealer; they referred me back to MTD. Called TSC; same results. Found another place online; they show the part; but they were out of stock; had 4 backordered; and the price $84. I can buid a better bumper than they show a lot cheaper. Thanks for the advice. TJ
There is a reason the part# is no longer available, it's because the machine is not supposed to be used in a pulling capacities. The EZT transmissions will not hold up to pulling a trailer. I personally wouldn't even attempt to pull anything with the RZT.
ya, you should probably invest in a used garden tractor if you want to tow a smaller trailer
Again Thanks for the help. BJC 's pix is exactly what I want to do. I do still have a '03 Craftsman 48" with a Kohler 23; but needs to be retired; more -'s than +'s. would take more to repair than to replace. Again; thanks for the help..
