Need motor for 1977 Toro Whirlwind II 19 inch mower
1977
  • / Need motor for 1977 Toro Whirlwind II 19 inch mower
Motor finally pooped out. Runs great but dies as soon as a load is put on it. Local shop couldn't find any later replacement motor that would work with the aluminum deck. One problem was replacement motor had too long a shaft and another was the bolt pattern was off making the motor sit at 45 degrees or so off original. Would really like to continue to use the original deck as I put much better wheels on it so very light and super easy to push. Any ideas? Thanks!
How about getting us the model, type, and code off of the blower housing for the engine so we can see what features you engine and need to compare it to.
1977
Briggs and Stratton 3.0 HP
Model 92508
Type 0951-01
Code 77020405
