Walk behind Need Lawnboy model 680532 Rear Drive Wheel
Eli2018
Need 8 inch diameter rear drive wheel for model 680532 (serial #L series). Part #683626. Gear drive wheel with a grease fitting on outside. Wheel itself is okay but tire is split. Is the tire replaceable?
Hi there. Welcome to the forum. It seems these wheels are no longer available. I did see a used one for $65 and also a pair for $85 plus shipping on Ebay.
These wheels are different than most lawn boy self propelled wheels. Do a online search, you might stumble across some NOS ones somewhere. Good luck.
Jerry
Did you ever find a wheel ? I have one just like you described..I seen a video on you tube , a guy used an old Bike tire to recap his drive wheels. I am thinking about doing this adding more Silicone to build up the lost tire..
