Walk behind Need Lawnboy model 680532 Rear Drive Wheel
Eli2018
Need 8 inch diameter rear drive wheel for model 680532 (serial #L series). Part #683626. Gear drive wheel with a grease fitting on outside. Wheel itself is okay but tire is split. Is the tire replaceable?
viperv10
Hi there. Welcome to the forum. It seems these wheels are no longer available. I did see a used one for $65 and also a pair for $85 plus shipping on Ebay.
These wheels are different than most lawn boy self propelled wheels. Do a online search, you might stumble across some NOS ones somewhere. Good luck.
Jerry
icurious1
Did you ever find a wheel ? I have one just like you described..I seen a video on you tube , a guy used an old Bike tire to recap his drive wheels. I am thinking about doing this adding more Silicone to build up the lost tire..
