Need Ignition Coil B/S 793352
ABrosz
Hi and Hello:
I need an ignition coil for MTD 4 HP 22 inch cut push mower. B/S Model:10A902 Type: 2189 B3 Code: 01102654. An in-line spark tester shows very faint spark. Also, mower was purchased in 2002 and has slight "backfire" in exhaust, hardly can hear it but just started. I am suspicious of ignition but probably carburetor. Carb has new gaskets and totally cleaned.
I could purchase Chinese aftermarket type but web says compatibility issues for direct fit.
Anybody have a used one?
Thx in advance.
Auto Doc's
You need to use an adjustable gap spark test and get rid of the inline "Christmas" flashing light type spark tester.
You can get a coil from Parts Tree or Jacks small engine.
sgkent
I looked it up and directly from Briggs it is only $43.59. These days that is a McDonalds meal.
Being an old L head it is possible you have a valve issue.
