No, even if you got the mower for free.. If you could find parts for it, they would be costly, and if you spent a bunch of money to fix it all up, it still
wouldn't be worth much.
Well I picked it up and it works, I have to add a woodruff key to he rear axel and I might clean the carb up. I starts to dy when I start to mow the lawn. I think that it hasn't run in such a long time that it needs to have the gas run though it. Spark plug needs to be replaced.
I think it will run pretty good after the updates to it. Very clean and well kept when I picked it up. Very little rust! It is a Murray 5hp Briggs & Stratton 206cc engine , 3 speed, 25 inch blade. 5/25. All original parts. It has a peerless transmission from Tecumseh. I am quite happy with the purchase, its was only 45 bucks. I have been looking for parts and there are some out there. I have not been able to find the manual for it. The opposite side of the RER, the decal is completely worn out.
