well what size carb should i get and what kind of cam
L lm racer Member Joined Dec 5, 2012 Threads 1 Messages 10 Dec 6, 2012 / need help #11 well what size carb should i get and what kind of cam
Flintmotorsports Well-Known Member Joined Dec 2, 2012 Threads 14 Messages 318 Dec 6, 2012 / need help #12 well you would have to know what you are doing with it and if you race vs pull the cam will be diffrent so will the carb
L lm racer Member Joined Dec 5, 2012 Threads 1 Messages 10 Dec 6, 2012 / need help #13 all i really want to do is max out the speed and make this mofo hall ***
L lm racer Member Joined Dec 5, 2012 Threads 1 Messages 10 Dec 6, 2012 / need help #14 If i can get it runing and going im going to be entering it in the lawn mower pull at field day of the past next fall and if they have a race im probley going to enter that to
L lm racer Member Joined Dec 5, 2012 Threads 1 Messages 10 Dec 6, 2012 / need help #15 by the way how much would it cost if i took it to the shop and got them to put the bigger carb and cam on it
Flintmotorsports Well-Known Member Joined Dec 2, 2012 Threads 14 Messages 318 Dec 6, 2012 / need help #16 so why do you do this fix what you got and chain the pulley and you will be read to go but you will need diffrend pulley for each event
L lm racer Member Joined Dec 5, 2012 Threads 1 Messages 10 Dec 6, 2012 / need help #17 cant you put a chain and sprocket on it or does it need a pully
Flintmotorsports Well-Known Member Joined Dec 2, 2012 Threads 14 Messages 318 Dec 6, 2012 / need help #18 i would just put a pulley and a belt on it it is more simple and all you would have to do is change the rear pulley if you want or change both
