Need help with Walbro carb. It's on a "28n700" B&S 15.5 HP. 1999
smalltimerpm
  • / Need help with Walbro carb. It's on a "28n700" B&S 15.5 HP. 1999
Are you actually smelling rich out of exhaust? If you pull the plug what color is the insulator? Also check your breather hose that runs from top of gas tank back to the walbro carb. for that will let you smell gas fumes in some cases
