Need help with this mower
Curt1970
I bought a used trail mower and now I need some help figuring out who made it. I'm in the need of parts but cant find a model number anywhere. I have photos but the file Is to large. How do I shrink them to fit?
upload the pics to postimages.org and place the links here.
Ok thanks. I will try that. Until I can get where I can get a good phone signal or wifi I wont be able to do it. This mower has had all the tags removed that I can see. Is there some other place where swisher might have stamped a model number? Underneath? Motor mount? The mower I have looks something like this one. Its longer and black, though. It has a shield/ guard like in front of the motor with the ignition and throttle mounted there. The height adjust is set by two handles, one on each side of the deck. Motor is front mounted with the gas tank on the back and raised above the motor. I will get pics of mine on here as soon as I can.
Yeah but longer. Fuel tank up above and behind the engine. It's an older model. I know the engine is from around 08.
