Need help with screw size
Jolive
I have this mower, but have lost the shroud screws. Any help on finding the correct size replacement?Screenshot_20220330-185104_Google.jpg
Lets start with both the model number of the engine and the model number of the mower. That have used both phillips headed and hex headed screws to secure those in the past.
If remember correctly they are Briggs PN 691138 which a plastic mounting screw with a double thread design. But there is one other screw design for mounting into metal.
Scrubcadet10
Moderator
Staff member
I've had maybe a handful of engines come on with the appropriate screws on the recoil cover. Usually a Phillips wood screw in its place.
sgkent
Briggs model # =
Crafrsman mower part number =
Serial number if known please =
should be on a tag on the side of the engine shroud if I recall
Briggs 128T02-1270-B1
PN 691138 Screw
Looks like it should be part number 690700
Looks like the Craftsman parts diagram is calling for the 690700 and the briggs diagram is saying it is 691138 but both were used on that model of briggs engine depending which decorative cover was used.
The 690700 is for the following cover.
