Need help with murray lawn mower
mechatoine
Hey guys! I'm new to the forum and I need advises on how to fix my Murray lawn mower. I bought it one year ago and it worked perfectly for 2012 season. In November I had it out in the yard for 5 minutes and it just stopped working on me and impossible to restart it, so I left it in the garage until I would fix it. Now is the time... So, the symptoms are strange. It just won't do anything when I turn the key in the ignition. Neither turn the lights on or crank the engine... I replaced the battery with a brand new one and still nothing happens. I checked the ignition switch and it seems good. It's like there is something that keeps the electricity out of reaching the main circuit. I just don't really know where to look at this point? Could anybody tell me where and what to look for? I'm a little lost here...
Try this troubleshooting procedure if you feel you have the electrical skills.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). *If you have power what is the voltage?
Fifth, check for power at the starter while holding the key in the start position (assistant again). *If you have power what is the voltage?
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
Since you purchased the mower a year ago in 2012, and eliminated the battery as a problem, I would get it to a service dealer for possible repair under warranty.
I second what IL said. I missed the fact that this unit is still under warranty.
jtannos
You might look for a blown fuse. Mine has a 15-amp automotive-type fuse installed near the solenoid.
