Then I would look at the ground cable where it bolts to the frame. Also, remove the spark plugs and crank, see if you get a bunch of fluid spraying out.
I have taken the ground off and cleaned it. It was bolted at the motor mount bolt. I also have removed the plug just to see if that would let the engine spin over easier with no bad motor noise and it did. I did not see any fuel spraying out then.
