Repairs Need help with a mower not starting
luthien
19 hp Craftsman mower wont start. Was running two days ago. Any help is appreciated.
Sounds like loose battery connection at battery,starter or starter solenoid
that rapid clicking is a dead or low battery.. put it on a charger until it gets to about 12.8 volts (if you have a multimeter to check it with), if not just leave it charging for 5-8 hours. that usually gets mine charged up.
When you say "not starting" do you mean starter is not turning engine over or----engine is turning over but not cranking????
OK thanks, a picture(video) is worth a thousand words :wink:
I had a similar problem with my Craftsman Riding where I had a new battery that would not stay charged. I kept messing with the electrical connectors until
it started working and staying charged. It was a bad ground clamp right below the solenoid switch was not making connection to the frame.
Of course that may not be your problem at all but a similar result. Bob
Thanks everyone. I'm going to tinker with it with these in mind and see what I can figure out. I'll post what I find out. Thanks again
