need help to wire a riding lawn mower
VITO55
Yeah, it would be fairly simple to help you rig up a simple start/run/stop scenario, but we need to know what you have, and the spec numbers off of the tag would tell us.
the motor model is a cv15s if that helps
VITO55
I have been repairing wiring for years and know what I am doing. It looks to me you a mixing up two different mowers with different wiring harnesses. I would say get the model numbers and find a wiring diagram. You need something to fallow. You would need this also even if you are going to install your own wiring. If you are going to make your own harness either number the wires or get different color wires or you will soon be over your head in problems.
model is a cv15s the harnesses were not mixed up. i made sure of that.
