tonyb mowing
- Oct 20, 2013
- 1
- 1
I am trying to rebuild a 1975 210 john deere lawn tractor , I put the new crank in and lined up the mark with the cam, then rotated the engine slowly by hand and set the piston up to top dead center on compression stroke then checked the valves to make sure they were closed . at this setting the points were opened. there is a timing view hole on the engine cover with two marks on the flywheel ( t ) mark and ( s ) mark. the ( t ) mark is lined up with the timing mark. is this all correct or do I have something messed up. thanks for any help as I know I will need it
