Repairs Need help--starter electrical problem
ntp
Thanks for the switch info, I will pull it out again and put a meter on it to check, The switches look the same physically,with one exception. On the 14 hp there is an extra red wire, but no terminal on the switch to connect it to. It just hangs there and there is no evidence that there is a missing terminal to connect it to. The Simplicity parts breakdown shows only 1 switch for both the 14 and 14 hp Regents, PN 1715017.
