Attachments need help on how to swap plow on a 1993 gt6000
hi i have a plow i want to mount ive checked and its the right year with all mounting pieces but im not sure how to remove the deck mounts and swap it any help would be aprecieated will post pics soon
heres a pic of model of tractor and plow mount have to unbury plow in back of shed tommorow the mounts and plow are from my other model witch is 5 years older but frames are identical and deck lift mounts are too
red one is what im swapping plow to the grey one had it on it
i took the mounts off today from the grey one but gotta mow one last time tommorow before i do the swap
grey one runs but fuel pump is out and after only running 20 minutes on fresh oil it is pure black and reeks of gas so i think engine is shot and also has been pouring oil outta the tubes going from the valve covers to the air cleaner
gonna rebuild it over winter
thanks for help finished the swap today took 4 hours mainly trying to get the lift adjustments right heres a pic sorry bad quaility cause its dark still dosent lift high as i want but its to dark to see
had to do a little modification to mount but its working good
