Need help! Kohler K321 no spark
motoman
If you are ambitious you could remove the harness, lay it on a big surface and copy a new harness. This can be a major PIA and would require correct gauge wires in place and a knack for soldering or crimping. If (the machine is worth it) you are pressed for time I would see if you can buy a new harness. Restoring a burned harness with electrical tape can be tedious and the tape may not provide enough insulation resistance. Also some of the wire may have been embrittled which may snap under vibration. Patience and good luck.
coinman66
Yes I was gonna make my own harness but think I will just buy a new one. Only $50. Since this tractor was given to me with a 48 inch deck and a snow thrower, I think it's well worth fixing. A 1978 model back when they were made good!
