Trying to figure out if rebuilding the engine is worthwhile. I don't do this often (2nd one) but my first one was in better shape yet worse running condition. The engine started leaking oil while mowing and it came from the sump area so while I had it opened I tore it apart to check everything.
So I need a new connecting rod it seems like.. quite a bit of scoring and can easily feel it. I doubt you can sand it because it would be larger and its impossible to sand perfectly. I think the crankshaft is ok but I was hoping someone could double check my assessment. It is possible to try to run some 1000 grit emory on it if needed?
Also the cylinder(cant really feel the scoring) and piston seem serviceable or do you recommend I hone it since its torn apart? Would have to figure out where to rent one or buy a cheap stone one.
Oh I almost forgot, thanks in advance for the help.
