Need help identifying
Murray_Mike
Can anyone help me identify what I have. I know it is a Murray. The guy I bought it from advertised it as a Noma. S/N is: 95073-055486. No Model # that I can find. It is a 14.5 hp techumsa motor and should have a 42" deck. Would like to find a manual, deck, rear bagger, snow equipment and tiller if possible.
Can you post a close-up of that sticker on the back? Also, there are some other places models are posted, like under the seat, on the frame by the engine, or hiding behind one of the rear wheels.
OK... I think I got it (Thank God for insomnia)
It looks like you have a 1996 model, that was manufactured on March 14, 1995. Unfortunately, your model number could be any one of like 46 listed on this page https://www.ereplacementparts.com/murray-lawn-tractor-parts-c-17887_17888.html, starting with 428035A, to 42918X8B, but probably one of the first 20 in that number range. You are just going to have to look up the specs for each one, until you find one that's closest to yours.
The engine isn't listed on those diagrams, however, so you will have to look up parts for that by the engine's model and code.
That's the best I can do, Good luck. Hopefully someone else can get you closer.
