Need help identifying the carburator on a Troybilt Pony w a B&S 500cc 17.5 HP engine
75Gremlin
The engine also says Powerbuilt on it, but I can't make out the serial number. I did find a
Model Type Code on a piece of metal near the muffler if that helps:
310707 3346 G2 101124ZA
If someone can help me ID the carb, then I can go to the following link to try and troubleshoot it. Apparently, the float valve in the carb has failed.
I can't post a link, because I'm a newbie, so I posted the link without the "http//:" just so you can see where I will look to help troubleshoot.
outdoorpowerinfo.com/repairs/#id_briggs
THANK YOU
Re: Need help identifying the carburator on a Troybilt Pony w a B&S 500cc 17.5 HP eng
594593 Carburetor
(Nikki) Used After Code Date 08051300 Used Before Code Date 15113000
.....I can't identify that particular carb at the following website. ......
(see below, I have to have 5 posts that count in order to include a valid link. Next post counts as #5)
Google these numbers 594593 look at the images
I appreciate all the help so far, but due to my ignorance, I'm having still having trouble identifying the carburetor. I attached three photos (one of the mower itself). In addition to the comments in my first post: In one of the photos, the spot where I am pointing is approximately where I noticed gasoline dripping from the breather hose on the day the lawnmower failed.
Is it a matter of just taking off a couple of nuts, etc to remove the carb?
thanks again
I just found the video below on Youtube, I think it may help. Maybe you know of a better video?
Briggs and Stratton INTEK OHV Engine: CARBURETOR REBUILD & Repair. Riding Lawnmower LEAKING GAS FIX:
https://www.youtube.com/watch?v=yyncpDD2DPI
Exact video I was going to post, your carb may not have to go through EVERY step he's doing .. SEE THE EARLIER REBUILD GUIDES I posted on rebuilding your carb. Keep us posted as to your progress
REMEMBER TO TAKE LOTS OF PICS BEFORE AND DURING your work, especially the linkages, be careful with the long thin choke return spring ...............
