Export thread
Need help identifying the carburator on a Troybilt Pony w a B&S 500cc 17.5 HP engine
#1
75Gremlin
The engine also says Powerbuilt on it, but I can't make out the serial number. I did find a
Model Type Code on a piece of metal near the muffler if that helps:
310707 3346 G2 101124ZA
If someone can help me ID the carb, then I can go to the following link to try and troubleshoot it. Apparently, the float valve in the carb has failed.
I can't post a link, because I'm a newbie, so I posted the link without the "http//:" just so you can see where I will look to help troubleshoot.
outdoorpowerinfo.com/repairs/#id_briggs
THANK YOU
#2
L
Luffydog
Re: Need help identifying the carburator on a Troybilt Pony w a B&S 500cc 17.5 HP eng
594593 Carburetor
(Nikki) Used After Code Date 08051300 Used Before Code Date 15113000
#3
75Gremlin
Thanks, however.....
#4
75Gremlin
.....I can't identify that particular carb at the following website. ......
(see below, I have to have 5 posts that count in order to include a valid link. Next post counts as #5)
#5
75Gremlin
http://outdoorpowerinfo.com/repairs/#id_briggs
Maybe someone can point out which B&S carb it is.
Thanks
#6
L
Luffydog
Google these numbers 594593 look at the images
#7
Boobala
Boobala
Your carb should be similar to one of these models, one is a ( NIKKI) other is a (WALBRO) basiclly the same, see the following guides ...
20428d1399153792-engine-flooding-even-when-turned-off-craftsman-lts2000-w-19-5hp-briggs-stratton.jpg
http://outdoorpowerinfo.com/repairs/briggs_intek_single_ohv_nikki_carb.asp
http://outdoorpowerinfo.com/repairs/briggs_28b702_carb.asp
#8
75Gremlin
I appreciate all the help so far, but due to my ignorance, I'm having still having trouble identifying the carburetor. I attached three photos (one of the mower itself). In addition to the comments in my first post: In one of the photos, the spot where I am pointing is approximately where I noticed gasoline dripping from the breather hose on the day the lawnmower failed.
Is it a matter of just taking off a couple of nuts, etc to remove the carb?
thanks again
75Gremlin
I just found the video below on Youtube, I think it may help. Maybe you know of a better video?
Briggs and Stratton INTEK OHV Engine: CARBURETOR REBUILD & Repair. Riding Lawnmower LEAKING GAS FIX:
https://www.youtube.com/watch?v=yyncpDD2DPI
#10
Boobala
Boobala
Exact video I was going to post, your carb may not have to go through EVERY step he's doing .. SEE THE EARLIER REBUILD GUIDES I posted on rebuilding your carb. Keep us posted as to your progress
REMEMBER TO TAKE LOTS OF PICS BEFORE AND DURING your work, especially the linkages, be careful with the long thin choke return spring ...............
#11
75Gremlin
Thanks
One question. We live in a remote area.
Is there a carb rebuild kit that contains everything needed (float, o-rings, etc)?
Otherwise I'd have to go back and forth the a shop where I can buy parts.
Where do you guys buy your parts for these? I'm used to going to the auto parts store for my car parts. Never worked on a mower before aside from changing the air filter, spark plug and oil on my own.
If this gets too complicated, I may have to let my neighbor get it fixed at the shop, but I have a feeling they will charge him an arm and two legs :laughing:
thanks
#12
Boobala
Boobala
Thanks
thanks
I can't find your parts manual, are you sure the model number you posted is correct ..?? ( 310777-3346-g2 ) .. see if you can find any numbers on the carb body, ( SEE EXAMPLES ) & the make .. Nikki or Walbro ..... yes kits are available, very few kits come with the float, but USUALLY with everything needed for a standard O/H ....... or you might have a Chinese carb on that engine ..???
#13
B
Under the seat will be a tag with some numbers on it .
There should be a model number that starts with 13 or 14.
We need that number to properly identify the mower.
On the rocker cover of the engine should be a series of numbers labels "model" , "code" & " serial" these identify the engine
Again we need these numbers and so will the parts supplier.
#14
Boudreaux In Eunice La.
Thanks
thanks
Gremlin you have a Nikki Carb
I don't know why I didn't see your thread earlier ??? Maybe google ???
You need carb kit 796184 and they are 48 bux plus shipping....... I don't think I have one in stock cause they are a popular item.....
Jacks small engine repair and parts has them though...... I'll check my inventory for you.....I can ship cheaper.....
I think one of those links Boobala sent you is a step by step tutorial on how to properly tear one down and rebuild it.....
He might post it when he sees this.....
#15
B
THE carb in your photo is a Nikki and the instructions for cleaning it are in the link Boo sent to you.
They look a little different when on the mower with the air filter housing still in place.
The tube you point to is the breather tube.
What is happening is the float needle is not shutting off the fuel.
The float bowl has an air vent ( or the fuel can not come out ) so the fuel level gets higher till it pours out of this vent .
The fuel then runs down whatever tube is lowest , in your case the breather tube.
There is a big chance the fuel has also gone in to the engine and sump.
Do not try and crank the engine with the plug in because the cylinder might be full of fuel and this can cause damage.
