Need help identifying ignition module
Ocean909
Looks like your date code is 00 so 691450 is correct, but before changing the crank, I would make sure the blade isn't bent and that it is balanced.
blaster 2023
Will Do, I didn't think of a bent blade.
Thank You.
Ocean909
Check for balance too. If one side of the blade has more metal than the other it can cause significant vibration.
blaster 2023
I took the mower to a Snapper Dealer, the Crankshaft is not bent and the blade was sharp & Balanced. He installed the blade with a impact driver.
Vibrations gone. suggested I may not have had the blade tight enough.
