Mollys dad
I am looking at my neighbors Little Giant Blower that won’t start. It has 5hp Briggs engine model 135212, Type1216 E1,
Code 990901YB. With a pulsa jet carb that has a fixed jet. The only way I can get it to stay running is to spray gas into the carb. I ended up removing the carb and tank. Cleaned the tank as best I could cleaned the carburetor with compressed air replaced the diaphragm for the fuel pump even though it seemed fine. I also cleaned what I assume is the fuel pickup. Longtube There is also another tube coming off the bottom but it is not like any of the picture I have seen with one long tube and one short tube. The other tube the short one is about the the diameter of a dime and appears to be wrapped with something and it sits in what looks like bowl inside the fuel tank. Any ideas as to what might be the issue would be greatly appreciated.
