Hi,
I have a Craftsman Lawnmower 917.271552 and I still can't fix the clutch.
I can't get the gears to work unless I turn the engine off, but then when I start the engine the tractor starts moving and then none of the gears work.
I've watched videos and read the owner manual's instructions but nothing seems to work.
I adjusted the nut that moves the spring back and forth at different levels and this makes a difference on the brakes but not the clutch.
I checked all the parts and I'm not missing any.
When the tractor is cold, then I don't have any problems putting one of the gears but 2 minutes later the problem starts.
Any ideas?
Thanks,
Any ideas?
Thanks,
