JimmyJustice
- Jul 20, 2017
- 4
- 7
I am restoring a (circa 1954) Sears Roebuck power reel mower. Mfg by Yard Man for Sears, the plate on the mower deck indicates model number 123.8151. The engine is a Briggs and Stratton model number 500.105549 with a serial number 58687.
The guys sharpening the blades just called and indicated that they broke the bolts holding on the cutter bar. I believe these are the ones that also adjust height. Any suggestions on where I can find these bolts as well as any other parts for the mower?
Thank you.
Jim
Thank you.
Jim
