Need help finding a carb.
Yoshimower
Hi,
I have a lawn vacuum with a 8.75 Intek B & S engine.
The carb has this number on it. 7508S 26462.
Can someone help me find a source for the cab.
The engine has this number
7BSXS.2051HC 277317
Thank you
Unfortunately those number are worthless for looking up part. Your first number is a casting number from the carb and is something is may mean something the company that cast the carb. The second number is the EPA number which only is basically a registration number for the EPA to use.
The Horizontal Intek engine should have the model type and code stamped into the side of the valve cover and may start with something like 12
