Please help I have a husqvarna iz 4817 with the Kawasaki fh500 series engine when the clutch is engaged the engine bogs right down and the mower is definitely lacking power the deck belt tensioner rapidly flops back and forth and it won't cut grass I've adjusted the valves to spec and no difference I've replaced the belt , clutch and tensioner arm due to worn and broken bushing the carb has been cleaned all switches are working. Please help
