Gave my father-in-law my prized mower when I bought a home where I needed a rider. Mower is a Honda 215HXA but has no serial # on it anywhere. Metal tag just says 215HXA and below that is says "JH". So I can't advise serial number. Has blade brake, 5HP engine, and Xenoy deck w/ Hydrostatic drive. F-I-L is 83 years old and insists on mowing his yard and FIVE others as they are "OLD people". (he is not!). His son hit buffalo box with mower and thought was that crank was bent. Mower would start, but blades wobbled horribly. They removed blades and clutch hub wobbled badly so they suspected crankshaft. Mower has been sitting for few years and I just bought him a Toro with blade brake, Self-propelled, etc. I decided to bring Honda home and see for myself. Blades were beat up and off mower and when I pulled starter cord, blade brake "hub" wobbled badly. I sensed that crank likely had a stub shaft for mowers with blade brake that might be bent and worth a look anyway. This is best mower I ever owned and Dad was sick about this "gift" being ruined. I pulled very simple blade brake off mower which would still start, but just vibrate badly. Put dial indicator on stub shaft for blade brake (can these be bought separately?) and working with it slowly with small steel mallet, got all wobble out. Had .040" runout when I started, but .000" when I finished. Bought new blades and put everything back together. All it needs is new belt as belt has a break in it now and will likely split in two soon. New belt ordered.
Here is issue-Thanks for staying with me. Start mower and it vibrates BADLY. Engage blade and it is smooth as silk. Release blade clutch and vibrates and makes a sound like blade hitting something, but blade is not turning! Blade clutch is only a 1/2 belt pulley, a metal disk, a concave thin clutch disk, and a thick outer clutch hub that gets bolted through to crankshaft and then blades bolt to it. Not understanding why vibration is only when clutch is disengaged, I removed blades and all blade brake parts. Start mower, and now vibration is gone again. I can tilt mower and see that stub shaft for blade brake is true and engine with nothing on it is smooth as glass. Doubt crank could be anything, but fine. If I re-assemble blade brake and blades, start mower, vibration is back bad unless blades are engaged. Woodruff key is in place. Mowed front yard and pleasure of fine mower was back until I released blade clutch and vibration back. All that happens is hub slides up and down on stub shaft engaging or disengaging clutch. What could case blade brake installed to cause vibration unless new blades are spinning? I am sick!! Sorry to be so long, but wanted to be as complete as possible. I will likely remove blades and see what clutch hub looks like spinning vs. slipping and vibrating deck so bad muffler shroud vibrated itself OFF!
Bill
Portage, IN.
Bill
Portage, IN.
