oops, made a mistake when first posting this.
The belt called for is actually # 5103391. Ferris
had belt numbers listed for two sizes of decks.
So, never mind..................................... ;-)
IS 2000Z with 61" deck
I need to replace the deck belt and am confused about the
correct replacement part number and length.
The label on the deck says belt #5103395 and I see it has been
replaced with #5103872. I think both these are 163.4 inches.
The broken belt is 174 inches as best I can measure so there
is no way a 163.4 inch belt would fit.
I see a Ferris belt #5103871 that is 175.9 inches that I believe
would fit and adjust fine.
Any advise will be appreciated.
Kingfish
Kingfish
