RobertBrown
- Aug 20, 2010
- 33
- 1,279
:confused2:
briggs engine model# 124T020130E1
CARB MODEL# 792253
This engine has no primer bulb and has sit for several months after being run out of gas, now the engine will start when choked, run for 2-3 seconds and die. You can pull it 10 times and won't re-start regardless if it's choked unchoked open throttle or closed. Wait 10 or 15 and the same scenario,
I have removed an cleaned the carb 3 times the jet is clear, I think there is only one although the casting has 2 ports at the top of the pick-up.
Do I need a new carb or there something else i can do to aviod the 45-50 bucks one will cost.
Thanks for your help
CARB MODEL# 792253
