Need Advise on Rebuilding a B&S 22 V-Twin
Dave_Williams
I read I also need to match (or better) the amperage O/P of the alternator too, correct?
Craftsman Garage
You should get a 44 series Briggs. Very common but very good. Your engine has a 40xxxx model, so its a 40 series. You want a 44 series with a 44xxxx model number. Make sure the shaft size is the same.
Craftsman Garage
That would be perfect but you have to measure your pto shaft. What's your Husqvarna model? Deck size? If you want to buy a $700 engine, go ahead, but I would assess your riding mower's value. Is it worth putting an expensive engine in?
Tiger Small Engine
I would get a parts mower with a 44 engine
I would buy a good used riding mower and call it good. Why buy a used mower for the engine, put that engine in your riding mower with the bad engine? Just check it out thoroughly before buying.
