Need a pic of the throttle and choke linkages
Searles400
Does anyone have a pic or could take one to show me how your throttle and choke linkages is setup. Like which holes and everything. I've got a scag turf tiger stt61v-27ch with kohler command 27. I got it used and noticed the smaller spring was missing and I believe causing a surge when at idle. The larger spring was also in the wrong hole so I'm trying to get a picture to see how someone else's is setup Thanks in advance.
Searles400
Here's a pic of mine
Searles400
Almost 50 views and not one person can take a pic real quick. I'm begging lol
BlazNT
I have a 24hp Kolher with vertical shaft. If you think that will work I will take picture.
Searles400
I don't believe it would be the same but I really appreciate it. No one else has a 27hp kohler turf tiger?
clay45
Sorry. My TigerCat has a Kawasaki engine.
First of all I see that you don't have the patience of JOB. It's been less than twelve hours, do you think people are waiting to help you and should be at your beckncall? You don't even have the in site to provide the engine model and spec numbers. That being said here is a service manual, maybe it will help and don't expect a lot more with your expecting attitude.
http://www.mymowerparts.com/pdf/Koh...d-CV17-CV18-CV20-CV22-CV25-CV22-CV23-CV26.pdf
Searles400
So first let me say I was joking when I said no one can take a quick pic....hence following up with I'm begging lol. So no i dont think anyone is waiting to answer my every question. Second you must be pretty pathetic and miserable to come on here with that kind of attitude like I give a wooden nickel what you think of me. I was mearly making a joking statement that out of almost quick views no one had a 27hp turf tiger.....model ch740-0041by the way....thank you for the service manual but I already have the one for my engine but the diagram doesn't show exactly how mine is setup with regard to the linkages and how they are run....the reason I was asking for a picture. Thank in advance to ANYONE ELSE who may be of some help and please don't take my lighthearted kidding as being impatient.
BlazNT
Ok in your picture compared to the manual the small spring does not belong. The large spring goes in #2. Im at work right now and can not take picture. 4 pm before I can put one up. We have the same setup when it comes to the linkage by the manual.
Searles400
Thanks man but I don't think yours is going to be the same as mine. I appreciate it tho.
