Bill Crowell
- Oct 29, 2011
- 6
- 13
I replaced the Tecumseh motor on my Toro walk-behind mower with a Kawasaki 6-hp. vertical shaft engine (No. FJ180V). I need to find a cable and lever to actuate the ignition kill/compression release on the Kawasaki engine. The kill switch cable for the old Tecumseh wasn't strong enough to actuate the compression release on the Kawasaki. It is pretty hard to pull the compression release, so the cable needs to be reasonably hefty.
Thanks in advance.
Thanks in advance.
