Coelacanth64
- Feb 5, 2015
- Threads
- 10
- 47
Folks,
I have a Craftsman Model#316796170, gas trimmer, pole saw, tiller combo device, from circa 2006.
The machine will start normally, it will run at about 1/2 throttle, but it stalls when the trigger is pulled to wide open.
I noticed that the gas line was rotten, so I replaced it. I also installed a new gas line filter. The primer plunger is fine.
I mixed new fuel/oil mixture and filled the tank. I cleaned and re-oiled the air filter and re-inserted it.
I removed the carb and checked the choke mechanism. It seems fine. The throttle moves normally.
I also filled the sump with fresh oil.
I could not locate a replacement spark plug (RDZ19H) locally, so I ordered one. But, given that the machine will start on first pull, I’m doubtful that the plug is the issue.
I have not yet disassembled the carb completely. Is there a port that might be partially blocked?
Any suggestions are more than welcome.
Best,
Jack
Best,
Jack
