Need a coil for this engine, edge cutter
sc2dave
Model 92902 ,Type 2187-01, Code 82050605. This is from the cover that has the pull rope. This is a edger. Or,is there another number that I need to post?
591420 is the magnetron coil so you will no longer need the points. Can leave points in place but not connect wire from points. will need to run new wire to kill switch.
sc2dave
I don't remember seeing any points on this engine. Are they located right under the cover that has the pull rope?
They are under a cover, under the flywheel, under the recoil/engine shroud. Just easier to remove kill wire from current, tape it up, and then run a new kill wire to the new coil.
sc2dave
I tried uploading pictures that are from my cell, but it tells me that they're too big. Is there a way to cut them down? Also, the handle says king O' Lawn. Is this the same?
