Need a Briggs carb 799727
coinman66
Looking for a cheap Briggs and Stratton carb for a 16hp Vanguard engine. A Walbro LMT 4993 carb came off it. I believe the Briggs part number is 799727. Its a gravity flow carb.Know where I can get a used one?
Thanks
Post model xxxxxx, type xxxx, trim xx, so we can be sure on this vanguard, thanks. Should be data plate on engine with this information, also include code numbers, this information is needed to locate correct carburetor.
