excessivegentlemen
- Aug 3, 2013
- 8
I have a 2013 D170 got it at home depot for a steal with only 11 hours on it. The previous owner turned it in with a flat tire and busted belt, at least thats what home depot told me. So I sprung for it because it was nearly a grand cheeper than reatail. Well I have used it 3 times so far and during the first two cuts it ran perfect, then today when I went out to cut with it cut for about a half hour just fine then began sputtering and backfiring. I turned the blades off and did a few stripes around my hard to check and see if the issue was with the blades and even with the blades off it was sputtering/backfiring. It also would back fire when idling. Now this mostly only happened when it was at full throttle, when I throttled down it still occured but much less. I wonder if this is a spark plug issue or if it is something electrical. The RIO switch is really an odd feature and it buggs the hell out of me. I noticed the previous owner had taped it down to not have to use it all the time, I dont know if this could have messed something up or if it is loose and wanting to shut off or something. the mower is still under warranty but Ide rather figure it out myself if it is something simple or at least know what I am dealing with. Any help is appreciated.
