OldMasterTech
New Exmark Navigator:
I hit a small 6" piece of a 2x4 which broke all 4 shear bolts. Ordered & received parts from my dealer along with an exploded view printout of the deck.
My question refers to the space between the blade driver/blade assy. and the blade retaining bolt/washer. Why is this space present? When the shear bolts break, the space allows the blades to damage the baffles and sustain damage to themselves.
I don't want to re-engineer a potentially hazardous component but I think a loose metal washer or a tight hard plastic washer could be used in that space to hold the blades level when the shear bolts break?
TIA for any comments.
